Activity Forums Maxon Cinema 4D sewing pattern from 3d Model parts curves parts -> flat
  • sewing pattern from 3d Model parts curves parts -> flat
    Posted by Ronny Traufeller on May 6, 2017 at 8:35 pm
    hey,
    i was wondering, i want to cut a 3d mesh ( Human Body ) into a sewing pattern parts.
    So i need to make these parts flat i guess. Because they are curved when i take them from
    the body parts.
    how could that be done?
    thx in advance
    Ronny Traufeller replied 9 years, 3 months ago 2 Members · 2 Replies
  • Adam Trachtenberg
    May 7, 2017 at 3:40 pm
    Cinema doesn’t have a built-in function for this, unfortunately. The best I can come up with would be to work on the objects UVs — breaking them up into the appropriate parts and then running the Relax UV command to flatten them.
    Once that’s done you can create a python script using the code found here: https://code.vonc.fr/?a=16
    Run the script on your object and it will create a flattened object from your UVW map. Tested in R18 and it works.
  • Ronny Traufeller
    May 8, 2017 at 9:54 am
    Hey Adam,
    Wow!
    I already get to the uv relax method,
    but the Script you found seems amazing!
    I will Try that tomorow !
    Big thanks
    traufeller.de
