Activity Forums Compression Techniques Several rookie workflow questions
  • Several rookie workflow questions
    Posted by Eric Steinberg on June 8, 2005 at 9:30 am
    Hello,
    I own Sorensen Squeeze, but have not used it very much. I am working on a project in Adobe After Effects, where one of the delivered formats will be PAL video at 25 fps, 720 x 576 with PAL DV pixel aspect ratio of 1.07. To output from After Effects for compression, I can crop or output any way I want so I can have the best possible source file for Squeeze. I want to make a Flash .swf file for use on a web server. I am unsure about many things: Should I output an uncompressed avi for Squeeze, non-interlaced? Will the PAL DV 1.07 pixel aspect ratio cause problems like circles looking like ovals? If so, how can I avoid that? Should I output a 320 x 240 file with square pixels from After Effects instead? Is 320 x 240 correct? There are lots of fast moving graphics; will 12.5 fps suffice, or will it be jumpy? Sorry about so many questions at once, but I am fighting an insane deadline, my After Effects render will take 1-2 days (!), and I don’t have a lot of time for testing, so I hope somebody can help me out.
    Kind regards,
    Eric
    Eric Steinberg replied 21 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
