Activity Forums Adobe After Effects Expressions setValueAtKey integer problem extendscript
  • setValueAtKey integer problem extendscript
    Posted by Rainier Raydán on June 16, 2017 at 1:57 am
    Hi. Im trying to assing a textbox number to the first parameter of the setValueAtKey method.
    var xValue = myPanel.grp.panelThree.setX.text;
    var yValue = myPanel.grp.panelThree.setY.text;
    var zValue = myPanel.grp.panelThree.setZ.text;
    var kValue = myPanel.grp.panelTwo.setK.text;
    curItem.layer(1).property("ADBE Transform Group").property("ADBE Scale").setValueAtKey ((kValue), [xValue, yValue, 0]);
    when a put this it says “Unable to call setValueAtKey” because of parameter 1. is not an unsigned integer.
    the idea is set keyframe number by a textbox in my script UI.
    Rainier Raydán replied 9 years, 3 months ago 2 Members · 2 Replies
  • Dan Ebberts
    June 16, 2017 at 6:41 am
    It sounds like you need to convert your key number from text to an integer with parseInt(). You probably need to convert your x and y values as well, using parseFloat().
    Dan
  • Rainier Raydán
    June 16, 2017 at 10:43 am
