Setup Project with Correct Format
I am using Final Cut Express, and I have source material that is H.264, 640×480, and 29.97fps (and .mov extension). I don’t know what format to use in Easy Setup or if I have to convert the files to something else first. As of now, the files will work, but they are not the same dimensions as the sequence when I put them in the timeline. None of the formats in Easy Setup seem to match up with the source video that I have.
Also, once I get everything set up right, edited, and then ready to be exported, what would you recommend for export settings? This part always trips me up, and even though I come out with a finished product, I don’t really know how it worked, or if I could have done something differently.
Ryan
