Activity › Forums › Apple Final Cut Pro Legacy › Setup New MacPro with Default RAM or OWC Purchased RAM?
  • Setup New MacPro with Default RAM or OWC Purchased RAM?
    Posted by Cory Mckechnie on January 29, 2008 at 10:47 pm
    Just a quick question regarding the RAM I’ve purchased from OWC (which arrived yesterday) and my newly ordered MacPro. When the MacPro arrives, is it advisable to setup with the default 2GB of RAM to make sure it’s working properly, or can I go ahead and replace it with the 8GB OWC RAM? Just wondering as I’ve been reading not to sell the default RAM, but rather to hold onto for troubleshooting any problems later.
    Thanks for any help,
    Cory
    Cory Mckechnie replied 18 years, 8 months ago 5 Members · 7 Replies
  • 7 Replies
  • Paul Escandon
    January 29, 2008 at 11:17 pm
    I would recommend first setting up your system with the stock RAM and then when you’ve made sure everything is running correctly you should then install your OWC Ram. This is exactly what I did when I set up my system a few months ago.
    Also, if you go and sell your ram on eBay like I did (I had no use for it), you can at least be certain that it’s not faulty.
    Paul Escandon – Lead Editor @ Outdoor Channel
    Producer | Director – Oremus Productions
    oremusproductions.com | blog
    Apple Certified Trainer – Final Cut Pro
    Adjunct Professor of Media – JPCU
    MacPro Quad-core XEON
    8Gb ram, ATI Radeon X1900 XT, 2TB internal RAID
    2 20″ Dell UltraSharps + Matrox MXO & 23″ ACD
  • Aaron Neitz
    January 29, 2008 at 11:27 pm
    I trust OWC enough just to put in fresh when your computer arrives. But definitely hold onto the Apple RAM for a time in case there are problems… Also Apple is a little pain-in-the-ass when you need warranty repair and have non-Apple RAM
  • Steve Eisen
    OWC will give give you a rebate on your original RAM. Go to their website to find the rebate form.
    Steve Eisen
    Eisen Video Productions
    Director-At-Large
    Chicago Final Cut Pro Users Group
  • Cory Mckechnie
    January 29, 2008 at 11:51 pm
    Hmm, I’m a little iffy about trading in the old RAM to be honest. I’ve heard Apple can be a bit picky about having other than their RAM installed for problems, so I think i’ll hold onto it, just in case.
    Cory
  • Cory Mckechnie
    January 29, 2008 at 11:54 pm
    OK, that was my inclination so I think i’ll probably go that way. And as you say (not that i’m going to sell it) at least i’ll know it WAS working if I encounter problems. Alright, that’s my decision made.
    Cory
  • Ben Holmes
    January 30, 2008 at 1:29 am
    Have a look at http://www.barefeats.com for their own analysis of OWC RAM and what you should do with your Apple RAM – you’d need a couple more 1Gb sticks if you wanted to leave it in, although I know that’s not what you’re suggesting.
    As far as worries about fitting OWC RAM, it’s not a real big concern. Apple only give a spec for RAM that can be installed, and the OWC RAM meets it – in fact as barefeats point out, the cooling fins are actually BETTER on the OWC RAM. So you’re covered as far as problems go. Memory rarely fails, and a quick search here will show you that OWC is pretty well considered for pro work. So sell or keep your Apple RAM – I’d keep it ‘cos it sure ain’t worth much these days…
    Ben
    Editec Broadcast Editing Ltd
    EVS & FCP specialists for live broadcast.
    OB Server 1 HD – Mobile FCP editing done right.
    https://www.editecuk.com/OBServer2.html
  • Cory Mckechnie
    January 30, 2008 at 3:37 am
    [Ben Holmes] “Have a look at http://www.barefeats.com for their own analysis of OWC RAM and what you should do with your Apple RAM – you’d need a couple more 1Gb sticks if you wanted to leave it in, although I know that’s not what you’re suggesting.”
    Thanks Ben, very interesting article. I thought briefly about picking up a pair of 1GB sticks to pair with the installed RAM, but I figure at some point down the road I’d like to go to 16GB, so I’d rather save the money now and put it towards other needed items (I picked up a 750GB Seagate Barracuda with the savings 🙂
    Cory
