Activity Forums Adobe After Effects Expressions setup composition height and width via expression
  • setup composition height and width via expression
    Posted by Ron Grev on December 13, 2017 at 8:14 am
    Hello everybody,
    because i hve to resize many many comps according to its content it would be geat
    to ajust the comp.height ahnd comp.width over expression (e.g. slider)
    is it possible in AE?
    Thanks Ronald
    Rainier Raydán replied 8 years, 9 months ago 3 Members · 6 Replies
  • Dan Ebberts
    December 13, 2017 at 4:44 pm
    No, expressions can only control the value of the property hosting the expression.
    Dan
  • Rainier Raydán
    December 13, 2017 at 6:54 pm
    Hi Ron!
    You can do that only with a Script. You can use mine
    function myScript(thisObj) {
    function myScript_buildUI(thisObj) {
    var myPanel = (thisObj instanceof Panel) ? thisObj : new Window("palette", "compSettings RR V01", [0, 0, 300, 300]);
    res = "group{orientation:'row', alignment:['fill', 'fill'], alignChildren:['fill', 'fill'],\
    mainGroup: Group{orientation:'column', alignment:['fill', 'fill'], alignChildren:['fill', 'fill'],\
    sizeGroup: Panel{text:'Panel Name',orientation:'row', alignment:['fill', 'fill'], alignChildren:['fill', 'fill'],\
    widthText: StaticText{text:'Width'},\
    editWidth: EditText{text:'', characters: 4},\
    heightText: StaticText{text:'Height'},\
    editHeight: EditText{text:'', characters: 4},\
    btnGroup: Group{orientation:'column', alignment:['top', 'top'], alignChildren:['fill', 'fill'],\
    runBtn: Button{text:'Run'},\
    // Adds resource string to panel
    myPanel.grp = myPanel.add(res);
    // VARIABLES
    var proj = app.project;
    var curWidth = myPanel.grp.mainGroup.sizeGroup.editWidth;
    var curHeight = myPanel.grp.mainGroup.sizeGroup.editHeight;
    var runButton = myPanel.grp.btnGroup.runBtn;
    // Assign function to UI elements
    runButton.onClick = function (){
    var selectedArray = itemSelection();
    if(!itemSelection()){
    alert("Select at least one composition.");
    }else{
    app.beginUndoGroup("changeCompWH");
    for(a=0;a0){
    return itemAry;
    }else{
    return null;
    // Setup panel sizing and make panel resizable
    myPanel.layout.layout(true);
    myPanel.grp.minimumSize = myPanel.grp.size;
    myPanel.layout.resize();
    myPanel.onResizing = myPanel.onResize = function () {this.layout.resize();}
    return myPanel;
    // Build script panel
    var myScriptPal = myScript_buildUI(thisObj);
    if ((myScriptPal != null) && (myScriptPal instanceof Window)) {
    myScriptPal.center();
    myScriptPal.show();
    // Execute script
    myScript(this);
    Just put the dimension you want, select one or multiple comps and click the Run buttom.
    If you want a slider (I do not recomend this) you can change the editText for a slider in the code.
    P.D. : Copy the code into a notepad and save it with .jsx extension. Then open it with File/Scrips/Run Script File…
    Bye!
  • Ron Grev
    December 14, 2017 at 8:36 pm
    Hello Dan, hello Raineier,
    thanks for response.
    The Script-Version seems to be good for project.
    But when i execute the script i alwas get the warning:
    Unable to execute at line 40. Expected: ;
    for(a=0;a0){
    Whats the mistake?
    And is it possible to dock the script-dialogue into the Interface over the ScriptUI Panels Folder?
    Thanks a lot!
    Ron
  • Rainier Raydán
    December 14, 2017 at 8:55 pm
    You can download the file here
    https://drive.google.com/open?id=18nkpVfR8P5DDzVYLn_2SYKiWPIaPRDJX
    just put this file in the C:\Program Files\Adobe\YOUR VERSION OF AE\Support Files\Scripts\ScriptUI Panels
    then you can dock it
  • Ron Grev
    December 15, 2017 at 7:46 am
    Hy Rainier,
    thanks a lot but i’m a little bit confused ☺ about the link.
    GDrive shows me a cryptic file named:
    changeCompWH_RR.jsxbin
    ☹ mybe a GDrive problem? try a zip?
    Tanks, Ron
  • Rainier Raydán
    December 15, 2017 at 2:01 pm
    Just download the .jsxbin file.
    Also you can download the zip file here:
    https://drive.google.com/open?id=1unO24GcuYT_zIkwGADcyGUzQCVN3PGTL
    Bye!
