Activity Forums Apple Final Cut Pro Legacy Settle a bet…
  • Steve Eisen
    December 29, 2005 at 10:14 pm
    Besides getting your levels correct, you need to make sure the audio input settings on your DSR-45 are correct. You have 3 input levels, +4db, -2db and -10db.
    Steve Eisen
    Eisen Video Productions
    Director-At-Large
    Chicago Final Cut Pro Users Group
  • John Fishback
    December 30, 2005 at 3:02 am
    I think the approach you take has a lot to do with the audio content you’re woking with. For straight ahead dialogue, narration-based tracks or commercial spots I have to agree with a couple of posters who advocate letting levels fall between -6 and -3. Obviously, you have to watch your transients carefully. I usually apply some compression to assure there are no errant peaks. I’ll even go through the track and make keyframe adjustments to contol audio peaks. The tracks are hotter and don’t need normalization (which is basically bringing the audio gain up to just below the clip point). It also makes a big difference when exporting audio tracks to DVD or for web use. If you understand the process, it works very well.
    However, for video or film projects that involve a lot of dynamics, I’ll average at -12 or -20 which allows for dramatic dynamics (explosions, etc.). I’ll always release the master with audio the way the client calls for it.
    John
    Dual 2.5 G5 4 gigs RAM OS 10.4.3 QT7.0.3
    Dual Cinema 23 Radeon 9800
    FCP Studio 5
    Huge U-320R 1TB Raid 3 firmware ENG15.BIN
    ATTO UL4D driver 3.50
    AJA IO driver 2.1 firmware v23-28
    SonicStudio HD DAW, Yamaha DM1000, Genelec Monitors
Page 2 of 2
