Activity › Forums › DaVinci Resolve › settings nightmare!!!!
Posted by Andrew Sableton on February 20, 2013 at 6:17 pmHi all,
Can anyone tell me what the key is to making the “System Config” setting hold between different databases? I have logged in as admin and saved it, but every time I create a new database, the “System Config” defaults back to the factory defaults. I must be missing some vital step…. please help!!!!
AS
Eric Johnson replied 13 years, 7 months ago 6 Members · 8 Replies -
Margus Voll
February 20, 2013 at 8:57 pmTry saving config in presets bin.
Margus
https://iconstudios.eu
https://vimeo.com/iconstudioseu/videosDaVinci 9, OSX 10.7.4
MacPro 5.1 2×2,93 24GB
GTX 470 / Quadro 4000
Multibridge 2 Pro -
Andrew Sableton
February 20, 2013 at 9:03 pmCan you explain what you mean in more detail?
Here is my process…..
Create a new database
Log in as admin
Click on the project settings cog icon
Make all my settings
Save my settings
Right click on my saved settings and choose “Save as System Config”Then when I need to create a new database for a new series I expect that I can just load the “System Config” settings and I’m ready to go….BUT IT DOES NOT WORK!!!!! “System Config” does not appear to apply to my system – just one database. Useless!!!! Unless I am doing something wrong???
Please help someone!!!
Rohit Gupta
February 21, 2013 at 1:38 amHi Andrew,
The System Config setting is database specific, there is no global setting across all databases.
The System Config get copied over to User Config for all new users added within that database.
Regards,
Rohit -
Gabriele Turchi
February 21, 2013 at 3:57 pmI still wish we could export the config setting as a file .
Otherwise when we need to work on another system we have to manually create the user and set everything manually ( and tehre are quite some preferences involved …)g
Davinci Resolve Control Surface
MacPro
Cubix desktop 4
2 Red Rockets
GTX470+GTX470+GTX470
24GB RAM
HP Dreamcolor
Panasonic 58PF Plasma
Ultrascope -
Joseph Owens
February 21, 2013 at 4:45 pm[Rohit Gupta] “The System Config setting is database specific, there is no global setting across all databases.”
Which, although not entirely convenient, might not be a bad thing.
And has been how it is for a very long time and reminds me of the days of re-setting systems with every new version of software, even in Renaissance times. (Yes, we were doing color correction in the 1500s) And each user would need to set up separate configurations for each telecine gate (35, 16, super16), and then we’d create scan and masking basemems for different stocks and apertures — for example 16mm Academy Vision2 500 on the ‘super-16’ gate (although in the late ’90s (that’s 1490, before Columbus!) you might use that for 80% of your schedule) — some pervert would come in (Savonarola was famous for this, so we learned to phone in “ill” on those days) and want the whole image area anamorphic, which is doctrinely *more pure*, which would change the scan patch enough -URSA CRT – to warrant a new TAF setup (so put up three film loops — the Kodak Telecine Tools grey chart, followed by the appropriate TAF loop for that stock, and then the Channel 7 16×9 ground glass… actually the scan patch needed to be done first, whoops start over…).Which would be good for a couple of months. So the permutations were large and really had to be checked for corruption every time you re-booted, anyway…
Then there was the confusion between what was a configuration basemem, user basemem and session basemem…
Frankly, I find Final Cut to be worse for pref corruption and getting blown away every time you update anything in the chain, with the added bonus that it doesn’t warn you about anything. At least DaVinci advises that you’ll have to update your database…jPo
“I always pass on free advice — its never of any use to me” Oscar Wilde.
Eric Johnson
February 21, 2013 at 5:45 pmCan’t you just build an empty project setup correctly, export it, then import it and copy it’s config to your system config? Or at least use it to make a default preset?
Then you just need to keep a project on your desktop, or wherever, and import, copy, create for every new DB…
Andrew Sableton
February 28, 2013 at 12:22 amYeah….good suggestion….this is what I have done thanks and will do as a work around until they return the functionality that was in Version 8 ( a touch of the FCP X debacle here!)…
S
Eric Johnson
March 1, 2013 at 6:09 amAlso, have you pushed the little network/server globe on the bottom left of the project pane? It allows you to select different databases and look through the different users and each users projects…
This sounds like what you’ve been looking for… it looks very similar to how the project pane looked in v8, in a v9 kind of way….. but it may be just different enough…
