Activity › Forums › Adobe After Effects › Settings in After Effects
  • Settings in After Effects
    Posted by Romulus on August 29, 2007 at 4:57 am
    I recently upgraded to CS3 and things have been running a bit slow. I realize now that many of my user prefernces are all set to default where as my CS2 settings had been tweaked over the two years I used that version.
    My question is what are the absolute best settings for AE CS3? In my case I’m using PC, QX6800, 4GB, nVidia 8800GTX (open GL support), and a RAID 0 set of drives.
    One thing that is particularly slow is when I RAM preview. It takes 5-10 seconds before it even starts to preview.
    Thanks in advance.
    Kevin Camp replied 19 years, 1 month ago 2 Members · 1 Reply
  • Kevin Camp
    August 29, 2007 at 1:43 pm
    i’m not familiar with your pc, but if it has multiple processors or cores, you can enable cs3 to use multiprocessing in the preferences. this will speed up renders and ram previews.
    also, if you can live without disk cache enabled, this can help speed things up. if you need disk cache for some renders, set your raid0 for the drive to use for caching.
    i’m not a big fan of opengl in ae, but if you check the help file for opengl, you will find a list of accelerated features and effects… if you use those feature/effects a lot in projects (things liike blending modes, motion blur, curves, gausian blur, etc.), then setting ae to use opengl always for previews, and also creating a render setting that enables opengl for final render (a check box in the render settings) may help out. however, opengl can get a bit flakey, so if things don’t seem to be working quite right in a project, try not using opengl and see if that helps.
    the lag for the ram preview may be due to the compression of the footage you are effecting… do you notice the same lag if you were to generate effect without any footage? like if you just put in a layer with fractal noise, animate the evolutions and ram preview, do you see the same pause?
    i’ve noticed that using footage that is compressed by a codec that uses temporal (or interframe) compression tends to create a pause prior to ram preview. using image sequences of any type, uncompressed formats or lossless animation codec are all good ways to avoid temporal compression.
    Kevin Camp
    Designer – KCPQ, KMYQ & KRCW
