Activity › Forums › Adobe After Effects › settings for the pal or secam
Posted by Mohit Sedaliya on January 13, 2011 at 8:13 amHi There,
I wanted to know that how can I render the originally NTSC to PAL in After Effects CS3, I need exact to exact project settings and after completing movie- render setting, because I want to render a movie (.mov) file which can run without any interruption in France.
Thanks.
Walter Soyka replied 15 years, 7 months ago 3 Members · 2 Replies -
Hamid Rohi-bilverdy
January 13, 2011 at 11:22 amTaken from the adobe Live documentations here
Convert footage items between video formats
You can use After Effects to convert one type of video to another. When converting video, keep the following in mind:
■Changes in resolution may result in a loss of picture clarity, especially when up-converting from a standard-definition format to a high-definition format.
■Changes in frame rate may require the use of frame blending to smooth out the interpolated frames. For longer footage items, this can result in very long render times.
1.Import the footage you’re converting into a composition using the preset of the format you’re converting to. Example: if you’re converting NTSC to PAL, add your NTSC footage item to a composition with the appropriate PAL composition settings preset.
2.Select the layer with the footage to be converted and choose Layer > Transform > Fit To Comp Width (or Fit To Comp Height).
Note: For converting between two formats with the same frame aspect ratio, either of these two Fit commands will do the same thing; if the frame aspect ratios differ (e.g., going from 4:3 to 16:9), fitting to width or height will choose between cropping or letterboxing the resulting image.3.Do one of the following:
■If there are no scene cuts in your footage, choose Layer > Frame Blending > Pixel Motion. This will provide the best results for interpolation of frames, but may require long rendering times.
■If there are scene cuts in your footage, or if you want to sacrifice quality for shorter rendering times, choose Layer > Frame Blending > Frame Mix.
4.Select Composition > Make Movie.
5.In the Render Queue panel, next to Render Settings, select the appropriate preset from the menu. For example, if you’re converting to DV footage, select DV Settings from the menu.
6.In the Render Queue panel, next to Output Module, select the appropriate output module preset from the menu, or select Custom to enter custom settings. For example, if you’re converting to DV PAL, select the D1/DV-PAL output module preset with the audio sampling rate that you require.
7.Click the name of the output module preset that you chose in step 6 to select additional Format Options.
8.Click the Render button to render your movie.
Walter Soyka
January 13, 2011 at 7:09 pmWhile standards conversion is possible in After Effects, Snell & Wilcox’s Alchemist PhC hardware is the gold standard for standards conversion.
Walter Soyka
