settings for the most high quality video
Posted by Pieper1 on December 15, 2005 at 2:22 amwhat should the settings be for the VERY BEST video. i need to know the settings for the project properties, the best settings for capture and the best settings for rendering.
Rob Mack replied 20 years, 9 months ago 3 Members · 3 Replies -
Gary Kleiner
December 15, 2005 at 2:43 amNot to be a smart-ass, but Best for what? That’s a term that needs a context.
What type of media? DV, HDV, computer generated?
What type of output? Tape, DVD, computer-based?Do you have a time constraint, or does the render time matter to you?
Gary Kleiner
Learn Vegas and DVD Architect
http://www.VegasTrainingAndTools.com
Pieper1
December 15, 2005 at 2:52 amsorry i should’ve specified that
i am using dv and i want to output to dvd, no time constraint.
file size doesnt really matter either but i dont want as it’s not a 100 gig file for 10 minutes of video
thanks
Rob Mack
December 15, 2005 at 7:16 pmWell, the best you can get would be to capture as DV (cause that’s what you’ve got) and then render direct from the timeline to MPEG2. This way there’s no rencoding as DV (in your transitions, for instance). This should be about the same as rendering as uncompressed and then rendering to mpeg2. The difference here is that you don’t get an actual uncompressed AVI file on your hard drive, and you skip a step.
There might be an advantage to having the rendered uncompressed master if you need to go back and add titles or something, but I think you could do without it.
Rob Mack
