Activity Forums Apple Final Cut Pro Legacy Settings for SD footage capture and sequence
  • Settings for SD footage capture and sequence
    Posted by Wes Browning on February 17, 2009 at 4:33 pm
    I’m editing a project mixing both SD and HD, and my question is about how to best capture the SD footage so that it will work well with the HD footage. Here are the major specs…
    The HD footage was shot with the Sony PWM-EX1. It was shot as 1280×720 at 30p.
    The SD footage was shot with the Panasonic DVX100B. It was shot in anamorphic squeeze mode at 30p.
    The final project will be a standard definition DVD.
    What settings should I use for both the sequence in FCP, and also the capture settings when bringing in the SD footage?
    Thanks.
    Nicole Haddock replied 17 years, 6 months ago 2 Members · 1 Reply
  • Nicole Haddock
    February 17, 2009 at 6:08 pm
    Clap the DP on the back next time you see him. I can’t tell you how many people shoot 4×3 on the DVX and think it will be easier just to blow it up in post. What maroons.
    That being said, you’re in an OK spot already if you just suck it up over firewire. You’ll be blowing the footage up 150% to fit in an HD timeline, but c’est la vie. Do you have a Kona card that will let you uprez on the ingest? That would probably be the ideal way to go. Cheaper alternatives include ingesting the footage as in into FCP, and then running it through AfterFX and have that do the blow up. After Effects actually does a good job at blowing footage up, changing frame rates, etc. Obviously not as good as a hardware conversion (Kona, Telenex, etc) but good in a pinch or for not alot of footage.
    I would also cut the piece in an HD timeline, even though you’re going out to an SD DVD at the end. The picture quality will be better and you never know down the line if you’ll go out to blu-ray, or upload it to the web in HD.
    What I can’t comment on is mixing Panasonic 30p footage with Sony 30p footage. Take in some of the SD footage over firewire and test it out in the timeline and view on a monitor. See what happens, or what else people post!
