Activity › Forums › VEGAS Pro › Settings for Projects and Rendering to Avoid “Lines”
  • Settings for Projects and Rendering to Avoid “Lines”
    Posted by Teachinfourth on November 4, 2006 at 7:26 am
    Hey All…
    I have completed a video and wanted to burn it to DVD but the video has “lines” through it. I have my project settings currently at:
    Field: Lower
    Rendering Quality: Best
    Blur Type: Gaussian
    DeInterlace Method: None
    Rendering settings:
    Save as type: MainConcept MPEG-2
    Template: Default Template
    Are these the best settings for viewing the film later on a DVD/television? I know that TV is definately lower field first but I was wondering if there were something I was forgetting or a setting I had incorrect? Any help to avoid the “lines” through the video would greatly be appreciated.
    Thanks in advance for any suggestions/help you could offer,
    Paco
    Gary Kleiner replied 19 years, 10 months ago 5 Members · 7 Replies
  • 7 Replies
  • Brian Findlay
    November 4, 2006 at 1:32 pm
    Hi Paco,
    Can you give a little bit better description other than lines? I’m just trying to understand, are they thick, thin (a pixel size or interlace) just at the bottom, all over, intermittent.. or what?
    Brian
  • Teachinfourth
    November 4, 2006 at 4:05 pm
    Hi, Brian.
    The lines usually occur where movement happens on the screen and these lines go through the entire moving object/person and are very noticable around the moving object’s edges…I have read up on a few forums and am pretty sure that this is from the interlacing of the video but not exactly sure how to correct it. I have tried a few different combinations of settings but still no avail…
    Paco
  • Terry Esslinger
    November 4, 2006 at 5:39 pm
    These are probably interlace lines. If your final media is due to be watched on TV (interlaced) you might try going ahead and burning a DVD and see what it looks like played back on the TV.
  • Teachinfourth
    November 4, 2006 at 11:34 pm
    I did. It looks as bad as on my computer. Isn’t there a way to get a video to look good on a TV AND computer? They do it with DVDs all the time…
    Paco
  • Peter Wright
    November 5, 2006 at 1:21 am
    Try changing the MPEG2 template – the Default Template is not recommended, despite its name – try a DVDA template.
    You could also try Reduce Interlace flicker.
    Peter Wright
    Perth, Western Oz
    http://www.allroundvision.com.au
  • Teachinfourth
    November 5, 2006 at 3:25 pm
    Thanks, I’ll give it a try to see if it works.
  • Gary Kleiner
    November 6, 2006 at 12:42 am
    Check the waveform monitor and see if your signal is below 0 IRE.
    Gary Kleiner
    Vegas Training and Tools.com
    Learn Vegas and DVD Architect
    http://www.VegasTrainingAndTools.com
