Activity Forums Compression Techniques Settings for Mpeg-4 in HD?
  • Settings for Mpeg-4 in HD?
    Posted by Per Rönnecke on December 3, 2007 at 12:00 am
    Hi! I will play a Mpeg-4 file in 1920×1080 25 fps on a PixelMagic Mediabox HD. What is the best settings for the compression to get a good result?
    The master file is 1440×1080 Apple Pro Res 422!
    /Per
    Per Rönnecke replied 18 years, 8 months ago 2 Members · 4 Replies
  • Daniel Low
    December 3, 2007 at 11:15 am
    How do you plan on using the Pixelmagic box, i.e. delivering to it over a network, or via an attached hard drive etc..
  • Per Rönnecke
    December 3, 2007 at 12:06 pm
    Hi! Just delivering from the built in HD to a flat screen via HDMI or analog component.
    /Per
  • Daniel Low
    December 3, 2007 at 1:13 pm
    AFAIK the box will only handle upto 1280×720 with MPEG-4. If you want 1920×1080 you’ll have to use MPEG-2 at around 28Mb/s. Obviously the box will upscale 720p to 1080p if you want it to.
  • Per Rönnecke
    December 8, 2007 at 11:05 pm
    Thanks, Danny! If I use Mpeg-2, does it need to have the audio muxed or can it take separate files?
    /Per
