Activity Forums Apple Final Cut Pro Legacy Settings and workflow advice badly needed
  • Settings and workflow advice badly needed
    Posted by Steve Foley on October 20, 2010 at 1:24 am
    Hi I need help!
    I’m not used to working in widescreen, so all of the various setup and rendering options in FCP are making me nuts.
    OK first of all — I’m using Voltaic to convert footage shot in the highest quality setting of my Vixia HFS10. The file dimensions come out to the expected 1920 X 1080. By the way, I’m using the VoltaicHD default settings cuz I’m working on a G5 Power Mac with Final Cut Pro 5.1.4 — the ProRes codecs are not available on that.
    Anyway — comes time to set up the project properly for this footage and I don’t know what to do. I’ve tried using the “Easy Setup” DV/NTSC Anamorphic — and exporting my Quicktime using “current settings” — and something just doesn’t look right. The footage doesn’t quite fill up the screen — no surprise when the rendered product dimensions are smaller than the beginning footage was.
    So I’ve also tried lots of “custom” combinations in both project setup and rendering — but just don’t know what is correct. Sometimes things look stretched out, sometimes squished, sometimes with letterboxing above and below the picture — etc etc. After a while it all runs together. I keep checking the results by going the long way round the barn and burning (widescreen mode) DVDs of each try and viewing them on both old 4:3 tube TVs and my brand spankin new Sony HDTV. Mind you, I’m making SD DVDs here — not blueray — but the resulting video should still fill up the screen, shouldn’t it??
    All I’m looking for here is a way to work with this footage so that the end result is actually WIDESCREEN — or whatever you call it — filling up the whole 16:9 TV. And it would be nice if the picture was in some way acceptable to viewers using the old 4:3 sets.
    Any advice on the proper way to do this would be appreciated.
    Steve
    Steve Foley replied 15 years, 11 months ago 2 Members · 2 Replies
  • Chad Tingle
    October 20, 2010 at 3:30 am
    Can you post a sample of the video so we can see what problems you’re experiencing
    Chad Tingle
    Producer/Editor
  • Steve Foley
    October 20, 2010 at 3:55 am
    Hi Chad
    Thanks for responding so quickly! I was just about to post an update — and that is that I finally worked the problem out. All it amounted to was working in HD 1280 x 1080 16:9 setup and rendering out in QT conversion using DVC Pro HD1080i60 compressor setting.
    Pretty obvious really after I put it aside for a while and then came back to it.
    Thanks again!
    Steve
