Activity › Forums › Maxon Cinema 4D › Setting up triplanar node based material
  • Setting up triplanar node based material
    Posted by Vedran Komlen on October 2, 2021 at 10:31 pm
    I’m trying to setup more complicated triplanar texture for cube objects in my project.
    My goal is to have controllable gradients on separate cube planes.
    I’m having trouble projecting repeating gradient on specific plane (+x,+y,+z)
    I’ve managed to get the effect I need on a simple plane using gradient and UV Transform nodes (Picture 1), but when I try to do it with triplane node it’s not working as I’d like it to. (Picture 2 – cube with white +X plane)
    First image is the effect I’m aiming for, repeating the simple black and white gradient on a specific plane, and the second image is me trying to set it up using triplanar node in C4D.
    I’ve realized my problem is in scale, so if the first color in gradient node is i.e. red, cube plane +x would be completely red, but other part of the gradient would not show no matter what settings I use in UV transform node.
    Also, I’ve tried plugging the UV transform node directly into the gradient node as result, but still, output is the same.
    Picture 3 (cube with striped lines) is what I’d like to get.
    Any help is much appreciated.
    Vedran Komlen replied 4 years, 12 months ago 1 Member · 1 Reply
  • Vedran Komlen
    October 3, 2021 at 1:11 pm
    I wasn’t clear in the first post. My goal is to keep the cube size properties to use them with Xpresso later. So making the cube editable is not an option for me.
