Activity › Forums › Apple Final Cut Pro Legacy › setting up system, need software advice
  • setting up system, need software advice
    Posted by Roli Rivelino on February 24, 2009 at 4:32 pm
    I’m just in the process of setting up a new system for HD and DV editing. I’m buying a Mac Pro desktop (specs below), I’ve got FCS and I need to know about extra bits of software I’ll need, I’m assuming I’m going to need Quicktime, but I’m doing a course at the mo and we’re using iTunes to resample and import audio;
    so I’m wondering if;
    I need iTunes on my system or is there a better alternative?
    and
    Do I need Quicktime pro and should it be latest version of QT or is there a preffered previous version?
    Also any further comments on my system specs would be greatly appreciated.
    Hardware:
    Mac Pro
    2.8GHZ quad core proccesor
    320GB 7200 hard drive
    1TB 7200 hard drive
    4GB RAM
    Geforce 8800 512mb graphics card
    20″ Apple Cinema display
    External hard drive Seagate 1TB USB 2.0
    Software:
    Final Cut Studio
    Many thanks
    Mike Raff replied 17 years, 7 months ago 3 Members · 4 Replies
  • Steven Gonzales
    February 24, 2009 at 5:37 pm
    If you have FCS then you have a license for Quicktime Pro.
  • Mike Raff
    February 24, 2009 at 6:22 pm
    As Steven noted above, you should find a QT Pro license key in your FCS 2 documentation, so there’s no need to buy it separately. Regarding iTunes, it’s handy for a number of things (and free), but you can also use QT Player to convert mp3s to AIFFs as long as the QT Pro functions are enabled.
    As for other software, it depends on your needs. If you will need to extract files from DVDs, MPEG Streamclip is quite helpful and also free. If you will have to export your finished programs as Windows Media files, then you’ll need to pay the $49 and purchase WMV Studio from Telestream. Get to know Versiontracker as a good source for locating applications that will suit your particular needs.
    Don’t forget the “Cow-Free Stuff” forum for tips on finding plug-ins, music, sound effects, photos and footage!
    As for your gear, sounds perfectly reasonable, except for the USB external hard drive. I’ve read that the USB transfer rate isn’t fast enough to keep up with Final Cut. FW 400 or 800 might be a better choice.
    Have fun!
    Mike Raff
    Richmond, VA
  • Roli Rivelino
    February 25, 2009 at 9:12 pm
    cool, thanks for the info.
  • Mike Raff
    February 25, 2009 at 11:06 pm
    I left one out. You’ll probably want to get an app for managing your Final Cut Preferences. Comes in handy when your system starts acting funky. There’s Final Cut Rescue, FCP Attic and Preference Manager. Some are free, some aren’t, some do more than others.
    Mike Raff
    Richmond, VA
