Activity Forums Blackmagic Design Setting up reference monitor with Deck Link Studio
  • Setting up reference monitor with Deck Link Studio
    Posted by Jay Lloyd on July 18, 2012 at 2:50 pm
    Hi all,
    I am trying to set up a reference monitor with After Effects CS5 using Deck Link Studio 2 via SDI on a Mac Pro.
    In the system preferences:
    Set output: All video, 4 analog audio & 2 AES/EBU
    Set input: SDI Video & SDI Audio
    Use video set up at in NTSC: at 7.5 IRE for use in the USA
    checked: Use 1080p no 1080PsF
    checked: Remove field jitter when video is paused
    Set default video standard as: HD 1080p 25 (Which is the format I usually work in)
    When not playing video: Black
    In AE preference:
    Output Device: Blackmagic Video Output
    Output Modes: (this is where I have problem)
    My comp is set to HDTV 1080p 25fps. But I couldn’t find a matching setting in the output modes drop down menu . I tried many settings, but none of them give me the result I was expecting. It either has this subtle but unbearable flickering/strobing or terrible interlacing(because I tried to set to to 50i).
    Does anyone have similar experience ??
    Jay Lloyd replied 14 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
