Activity Forums Apple Final Cut Pro Legacy Setting up offsets
  • Setting up offsets
    Posted by David Scott on July 22, 2005 at 9:38 am
    Hi folks
    I wondered if someone could explain the offset principle in “device controls”.
    When “editing to video” a finished project, the bars started at 09:58:30:00 both on the timeline and the tape after recording as I expected, but the bars overran the 09:59:30:00 point by 6 frames so the clock and following prog. at 10:00:00:00 started 6 frames late.
    I applied the “timecode generator” filter to the bars clip and played it out to tape to discover that it recorded the first frame (from the timeline) over 6 frames (on the tape), then began – thus causing a 6 frame freeze at the start.
    By applying a 6 frame offset in the device control tab I corrected this and it played out fine – but why?! I expected the offset to cause the recording to begin at a different point on the tape (by 6 frames) from the set in point. What’s with the freeze frames?
    If anyone could help me understand whats happening I’d be grateful.
    Thanks.
    David Scott
    FCP4.5 on G5 to BetaSP PAL.
    David Scott replied 21 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
