Activity Forums Apple Final Cut Pro Legacy setting up my G5 question…
  • setting up my G5 question…
    Posted by Third_man on September 25, 2006 at 9:11 pm
    I have a mac pro G5 and I’m using the four interanl HD bays in a RAID 0 configuration. My question is what can I use for my 5th HD, which will have my OS and other various programs, without degrading speed on it? An external enclosure utilizing the firewire 800 connection? The internal optical port? I just want to know the best way to maintain the best performance on it since its what i will be using for everyday use. Thanks
    Third_man replied 19 years, 11 months ago 3 Members · 6 Replies
  • Jerry Hofmann
    September 25, 2006 at 9:31 pm
    What kind of drive is it ATA or SATA? if SATA, I’d suggest an additional and inexpensive SATA card and enclosure… it’s faster than FW would be. As far as I know, it will be as fast as had it been one of the internal SATAs… otherwise, you’ll need to use FW 800 if it’s an ATA type drive.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Third_man
    September 25, 2006 at 9:38 pm
    Thanks Jerry – As an Apple certified trainer do you recommend a particular SATA card and enclosure? Should I worry about heat?
  • Jerry Hofmann
    September 25, 2006 at 10:11 pm
    I don’t have first hand experience, but the old main players here should be just great… weibetech or Granite digital sell first rate gear.
    Speed tests are done at https://www.barefeats.com might check there… faster’s better IMHO… any enclosure will be cooled enough from either of these companies.
    Jerry
  • 13 Create COW Profile Image
    13
    September 25, 2006 at 10:13 pm
    “I have a mac pro G5”
    Thats Amazing because the Mac Pro’s have Intell Processors insted og G5 Processors
    13
  • Third_man
    September 25, 2006 at 10:54 pm
    No whats amazing is that you care enough to post a correction….sorry, for all the dweebs out there its just a mac pro. hope you feel better.
