Activity › Forums › Adobe Premiere Pro › Setting up multiple program monitors
Posted by Igor Harmendani on August 13, 2013 at 1:43 pmHello everyone
I’m editing a project that was filmed with two cameras, I put camera 1 to layer 1 and camera 2 to layer 2.
But it’s quite annoying to hide the top layer everytime I want to see the layer below, that contais the first camera.
So, is it possible to set two program windows, each one for each layer, and still get previews at real time?
Igor Harmendani replied 13 years ago 3 Members · 10 Replies -
Igor Harmendani
August 13, 2013 at 6:20 pmThanks for the reply, Paul.
Your sugestion was a good idea, but is there a way to do it without nesting sequences or applying effects?
Ivan Myles
August 13, 2013 at 6:59 pmCS5/5.5/6 use the Muli-Camera Monitor, which has a track selector. I’m not sure if it’s still available in the new CC release. The following thread provides more information:
Where is the Multicam Monitor in Premiere Pro CC?
Ivan Myles
August 14, 2013 at 9:07 pm -
Igor Harmendani
August 15, 2013 at 12:49 pm -
Ivan Myles
August 15, 2013 at 5:51 pmGo to the settings menu in the upper right corner of the Multi-Camera panel and disable “Show Preview Monitor.”
Igor Harmendani
August 15, 2013 at 6:45 pmThat solved it! Thanks, Ivan!
And one last question, can I preview both layers, real-time, simultaneously? I can only get the program monitor to work when I play the timeline.
Igor Harmendani
August 22, 2013 at 12:49 pmThanks for the tips, Ivan, that video answered most of my doubts!
