Activity › Forums › Compression Techniques › Setting up multiple machines on qMaster for Compressor
  • Setting up multiple machines on qMaster for Compressor
    Posted by Brian Evancic on December 21, 2010 at 12:09 am
    I have three machines on a network I’m trying to set up in Qmaster to use all cores in compressor. I’ve done the steps to set up the three machines in Qmaster (sharing out compressor, sharing the main machine as quick cluster with services and the other machines as services only). When I run the cluster in compressor it seems to just be using one machine. The cluster is split to many different pieces but I only see my machines name. Is there something that I am not doing? Any suggestions would help.
    Brian Evancic replied 15 years, 9 months ago 1 Member · 0 Replies
  • 0 Replies
