Activity Forums Adobe After Effects Setting up for 235:1
  • Setting up for 235:1
    Posted by Mark on August 1, 2005 at 10:35 am
    I’ve been asked to produce some graphics that will be shot at 235:1 scope. Does anyone know the best pixel res to setup in?
    Thanks for any insight
    Barend Onneweer replied 21 years, 1 month ago 2 Members · 1 Reply
  • Barend Onneweer
    August 1, 2005 at 2:48 pm
    All depends on final output format.
    If it’s SD broadcast or DVD release, you’d be okay just working at NTSC or PAL res, and masking out the right aspect ratio.
    Generally it’s not a bad idea to work at higher resolutions, especially for film or HD output.
    Many feature films do post at 2k or 1080p, which corresponds with a frame width of 2048 and 1920 respectively.
    But seriously, I’d ask the client for some more specifications on their workflow so you can match those. Don’t forget framerate and bitdepth.
    Bar3nd
    Forum COWmunity leader for:
    ADOBE AFTER EFFECTS
    MAGIC BULLET SUITE
    INDIE FILM & DOCUMENTARY
