Activity Forums Maxon Cinema 4D Setting up an atmospheric/water background
  • Setting up an atmospheric/water background
    Posted by Ekpeti Chuks on January 20, 2018 at 9:28 pm
    Hi everyone
    Please I am trying to get this same background effect in cinema 4d. the cloud, the water surface, the underwater scene and the sea bed, all in one picture as shown below….please any help on how to go about that…Thanks
    Ekpeti Chuks replied 8 years, 7 months ago 2 Members · 4 Replies
  • Brian Jones
    January 21, 2018 at 4:12 pm
    the sky can be a physical sky or a regular sky with the right texture (or even a sphere) though the physical sky has much better haze/fog control so I’d try that to start. The water “fog” could be more of a problem if a volumetric fog was used but it looks like that could be done with nothing more than a ‘bottom’ texture that fades to blue in the right space for the camera alignment.
  • Ekpeti Chuks
    January 21, 2018 at 9:32 pm
    Is it possible to apply fog to just a material …maybe a cube ….can that give the effect I desire?
  • Brian Jones
    January 21, 2018 at 9:57 pm
    yes, you can but the fog falloff is a lot harder to control since you only have a distance parameter (which is distance from camera) and I don’t think you could get the tighter falloff needed. Give it a try though
  • Ekpeti Chuks
    January 22, 2018 at 8:32 am
    Ok thanks alot
