Activity Forums Apple OS X Setting up a Sony PVM-1450QM monitor in OS X Yosemite
  • Setting up a Sony PVM-1450QM monitor in OS X Yosemite
    Posted by Tommi Hakanen on November 17, 2014 at 1:21 pm
    I’ve hit a wall trying to connect a PVM-1450QM Sony monitor to my iMac. I’m using an sdi to vga cable that I connect to the computer with a vga to mini displayport adapter. The computer recognised a second monitor but the smallest resolution option I’m getting is 800×600, meaning I had to create a custom one with SwitchresX. Something obviously went wrong and crashed the OS and continues to do so even after removing the app and it’s system pane/preferences.
    Am I even able to get the right resolution set up for the monitor and therefore making this dual display work?
    Bob Zelin replied 11 years, 9 months ago 2 Members · 1 Reply
  • Bob Zelin
    November 27, 2014 at 3:50 pm
    You have an NTSC TV set that cannot display the hi resolutions of modern computers. Splurge and go out and get a computer monitor for $120 bucks, and you will be ok.
    If you want to see VIDEO playback on this TV monitor, you need a converter box from a company like AJA or Blackmagic that will allow you to display on your old TV monitor.
    Bob Zelin
    Bob Zelin
    Rescue 1, Inc.
    bobzelin@icloud.com
