Activity Forums Apple Final Cut Pro Legacy Setting up a routine?
  • Setting up a routine?
    Posted by John Cesere on October 6, 2008 at 2:49 am
    On some of my smaller projects i do a lot of editing while I shoot. I find that in post I end up wasting a lot of time setting IN and OUT points on each clip 15 frames on either side just so i can add transitions. is there a way to set up a routine so that i don’t have to manually do this to 10-20 clips in a row?
    Alan Smith replied 17 years, 11 months ago 3 Members · 3 Replies
  • Shane Ross
    October 6, 2008 at 4:38 am
    No way to automate marking 15 frames from the edge…sorry. Editing is a lot of work, and takes a lot of time.
    Shane
  • Alan Smith
    October 6, 2008 at 4:38 pm
    If you shoot with a camera that captures to solid state, like the P2 or the EX2/3, you can “edit” while you shoot and only import the clips that you want to use. It will actually create individual movie files that you can import without having to set in/out points (as long as you import the entire clip).
    Alan Smith
    Media317
    Check out my blog – https://media317.com
  • Alan Smith
    October 6, 2008 at 6:39 pm
    Alan Smith
    Media317
