Activity › Forums › Media 100 › setting up a raid Media 100 Hde
  • setting up a raid Media 100 Hde
    Posted by Greg Ball on November 5, 2006 at 8:02 pm
    I’m putting together my new Hde system. I installed a host card into my mac, and attached the sata drives with their enclosure. I will be ataching an additional SATA drive to this host card. I’m not sure how to set up the raid for this system. Do I set it up as striped? Mirrored?
    Do I use OS Extended or journaled? Any other suggestions? Thanks.
    PowerMac G5 Quad Caldigit S2VR 500GB SATA, G-SATA 320 GB drive and Fasta 4-E Host card.
    Thanks so much!
    Floh Peters replied 19 years, 10 months ago 3 Members · 6 Replies
  • David Issko
    November 5, 2006 at 9:09 pm
    Sorry I can’t be of any direct help to you but are you happy with the Caldigit HDDs?
    It seems that 500Gb may be too small, I don’t know.
    I am looking to get HD Suite once M100 is UB and I will go for a Mac Pro. I have 8.2.2 on my dual 2GHz G5 that works a treat. The Caldigit Pro SATA setup looks so nice (from an uncompressed operational viewpoint) and seems to be a great solution at a reasonable price.
    If you or anyone else has some feedback on Caldigit with M100 and high end HD like HDCAM – or anything HD, I would be most appreciative.
    Thanks.
    And by the way, my best guess Greg is Extended. I hope you find your solution quickly.
  • Floh Peters
    November 6, 2006 at 7:36 am
    For a RAID system you should use identical drives. If you want to work in uncompressed HD you would need at least 4 drives (probably more) striped as RAID 0 without journaling. Jpurnaling gives some additional data protection but slows down write access to the drives.
  • Greg Ball
    November 6, 2006 at 3:16 pm
    Thanks Floh-
    I’m working with Beta SP and Mini DV only. Do I still stripe them as raid 0 no journaling? Thanks.
    Also, I’m trying to figure out how to hook up the HDe junction box with my decks and monitor. The box came with a multipin cable that has numerous BNC Yrb and Yrc cables and some audio cables attached plus a Rs422 cable. Do all of these cables attach to my beta Deck (minus the AES audio cables I suppose)?
    Are these the inputs and outputs I need for my beta sp deck? Then what are all of the connections in front of the junction box for? Lastly how would I incorporate an audio mixer and NTSC monitor into this set-up? Thanks.
    Greg
  • Floh Peters
    November 6, 2006 at 3:20 pm
    [Greg] “Also, I’m trying to figure out how to hook up the HDe junction box with my decks and monitor. The box came with a multipin cable that has numerous BNC Yrb and Yrc cables and some audio cables attached plus a Rs422 cable. Do all of these cables attach to my beta Deck (minus the AES audio cables I suppose)?”
    You either use the Breakout Box with the cable that has the multipin connecitons on both sides, or you don
  • Greg Ball
    November 6, 2006 at 4:19 pm
    My monitor has standard BNC inputs. I’m not sure I understand, Why would I not use the multipin? Is it possible to use a combination? Does the multipin connect directly to the deck? Can I use the front audio inputs and outputs to connect to my Mackie Audio mixer?
  • Floh Peters
    November 6, 2006 at 4:24 pm
    [Greg] “My monitor has standard BNC inputs”
    Yes, but what signal? SDI? Component? Composite?
    [Greg] “Why would I not use the multipin? Is it possible to use a combination?”
    Look, you have one multipin connection on your HDe/Aja board. Either you use this multipin connector to connect the breakout box to the board with the supplied multipin/multipin cable, or you use the multipin to BNC/RS422/XLR connector cable and you forget the breakout box. You cannot use both at the same time.
