Activity › Forums › Adobe After Effects › Setting up a cheap broadcast solution from scratch
  • Setting up a cheap broadcast solution from scratch
    Posted by Craig Ricker on May 30, 2014 at 7:25 am
    Hi guys,
    Simply put, trying to setup a very low budget (under $50k) studio/broadcast setup for a 1 hour fortnightly forum show. I’m mainly looking for input here on the best way to do video playback through a BDM switcher.
    Heres what I’ve come up with so far:
    BMD ATEM ME2- $4835
    Alpha transitions, basic cutting, fades, clip store for guest/host animated supers
    The 4K will not be in use. But is there for future upgradeability of cameras if desired.
    Third party macro support for the BMD switcher
    XKeys 80 – macro keyboard – $200 x 3
    Just macros software – free
    BMD Studio camera – $1995 x 3
    Video Insert playback –
    Option 1
    Hyperdeck studio – $995 X 3
    1. Instant cue and playback VT inserts
    2. Motion graphics in background set
    3. Motion graphics in background set
    cons – no alpha
    Macbook pro or similar – $2000 (or use existing)
    HDMI output of premiere for animated name supers or name titles
    Option 2 –
    Basic PC tower – $1500
    BMD Decklink cards – $300 x 3
    CasperCG software – free
    Pros – allows alphas and a host of video processing and effects
    Second issue is point to point streaming. Essentially to transport our material to a satellite distributor such as optus or telenor, we wish to utilise an encoding unit to take our stream onto the internet and then receive it at the optus/telenor sites and convert it back to SDI so they can switch it to the satellite.
    The second half is what i’m curious about. Trying to find a cheap reliable solution to receive the stream and take to SDI. At the moment, I know we could just use a PC tower open up a web browser, and output full screen our stream playing back via HDMI and run through a HDMI to SDI converter, but wondered if there was a more elegant solution?
    Mac Pro 2.4Ghz 8 core, 24GB RAM, GTX 670
    Michael Szalapski replied 12 years, 3 months ago 2 Members · 2 Replies
  • Michael Szalapski
    May 30, 2014 at 1:14 pm
    This is more of an After Effects forum (granted, it’s labeled as “Broadcast Design” in some of the forum lists here…)
    I see that you have also posted in the broadcasting forum which will probably net you more useful results.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Craig Ricker
    June 1, 2014 at 11:57 pm
    Wrong forum I see. None of this stuff is rocket science, and even if it was, i’m sure I’d be able to work it out with time. Paying money to rent a studio is exactly why we are looking into doing one ourselves. We already have a purchased studio setup here in Australia with a grass valley. Looking to replicate its entire functioning in the UK on a much cheaper system setup. My main question here wasn’t, about an entire setup, but rather about playback systems integrating with the BMD ME/2 switcher that was all.
    Regards Craig
