Activity Forums Broadcasting Setting up a cheap broadcast solution from scratch – input welcomed
  • Setting up a cheap broadcast solution from scratch – input welcomed
    Posted by Craig Ricker on May 30, 2014 at 6:36 am
    Hi guys,
    Simply put, trying to setup a very low budget (under $50k) studio/broadcast setup for a 1 hour fortnightly forum show. I’m mainly looking for input here on the best way to do video playback through a BDM switcher.
    Heres what I’ve come up with so far:
    BMD ATEM ME2- $4835
    Alpha transitions, basic cutting, fades, clip store for guest/host animated supers
    The 4K will not be in use. But is there for future upgradeability of cameras if desired.
    Third party macro support for the BMD switcher
    XKeys 80 – macro keyboard – $200 x 3
    Just macros software – free
    BMD Studio camera – $1995 x 3
    Video Insert playback –
    Option 1
    Hyperdeck studio – $995 X 3
    1. Instant cue and playback VT inserts
    2. Motion graphics in background set
    3. Motion graphics in background set
    cons – no alpha
    Macbook pro or similar – $2000 (or use existing)
    HDMI output of premiere for animated name supers or name titles
    Option 2 –
    Basic PC tower – $1500
    BMD Decklink cards – $300 x 3
    CasperCG software – free
    Pros – allows alphas and a host of video processing and effects
    Second issue is point to point streaming. Essentially to transport our material to a satellite distributor such as optus or telenor, we wish to utilise an encoding unit to take our stream onto the internet and then receive it at the optus/telenor sites and convert it back to SDI so they can switch it to the satellite.
    The second half is what i’m curious about. Trying to find a cheap reliable solution to receive the stream and take to SDI. At the moment, I know we could just use a PC tower open up a web browser, and output full screen our stream playing back via HDMI and run through a HDMI to SDI converter, but wondered if there was a more elegant solution?
    Mac Pro 2.4Ghz 8 core, 24GB RAM, GTX 670
    M. Venom replied 12 years, 1 month ago 2 Members · 1 Reply
  • M. Venom
    July 2, 2014 at 6:22 pm
    If you are going with option go definitely include one Hyperdeck studio Pro, for the thunderbolt capture capability and as far as encoding you can run a computer with Telestream Wirecast, great encoding as well as live streaming.
    “Do Not Under Estimate the Power of The Darkside
