Activity Forums Avid Media Composer Setting TV output for Avid
  • Setting TV output for Avid
    Posted by Praveen Antony on July 5, 2009 at 1:14 pm
    Hello, I would like to set TV output for Avid. I am working with dual monitors. I am having nvidia Gforce 8500. Let me know wat r the things required and the process.
    Shane Ross replied 17 years, 2 months ago 4 Members · 3 Replies
  • Bob Zelin
    July 5, 2009 at 6:07 pm
    TV output for AVID occurs when you use AVID hardware, like an AVID Nitris DX, AVID Mojo DX, AVID SDI, AVID Adrenaline, etc. The video output of one of these AVID hardware boxes goes to your TV monitor.
    You can’t send a computer signal from your NVidia card (which has a DVI connector) to a regular TV monitor.
    Bob Zelin
  • Job Ter burg
    July 6, 2009 at 5:39 pm
    But there is the Full Screen Playback feature on software systems. It requires that you use one of your screens as a fullscreen monitor. A lot of modern TV’s have DVI/HDMI inputs, so you could use a Full HD TV for that if you like. And there’s Matrox MXO, at least: so I heard.
  • Shane Ross
    July 7, 2009 at 10:04 am
    Just to prove Job right…
    https://lfhd.blogspot.com/2009/05/matrox-mxo-and-avid-media-composer.html
    But yes…what Bob said. To get an image on your TV you need a capture card. Either the Avid hardware, or the less expensive Matrox MXO. You can’t capture with it….it is output only, FYI.
    Shane
