Activity Forums Adobe Encore DVD Setting Track order on Disc
  • Setting Track order on Disc
    Posted by Dan Mingo on June 23, 2008 at 9:15 pm
    Curious if anyone knows if you can set your own track order or is it not user definable? For instance: if I want (Timeline A) to be on track 7 and (Timeline B) to be on track 9 when programming a DVD player for playback without using the menu, how can I accomplish this.
    If you need more clarification please let me know.
    Joe Bowden replied 18 years, 3 months ago 3 Members · 4 Replies
  • Jeff Bellune
    June 24, 2008 at 3:30 pm
    Encore will write the timelines (tracks) to disc in the order that you create them.
    -Jeff
    The Focal Easy Guide to Adobe Encore DVD 2.0
  • Dan Mingo
    June 24, 2008 at 3:40 pm
    Okay, so let me make sure, there is no way to rearrange what order they go to disc after you have already created them? All have to be done in the order you want first? Thanks for your info.
  • Jeff Bellune
    June 24, 2008 at 4:18 pm
    Correct on all counts. You’re welcome. 😉
    -Jeff
  • Joe Bowden
    June 25, 2008 at 1:37 am
    If necessary, you can re-create the timelines in the exact order you want the video title sets to appear on the disc. You can also set any timeline to the Main Timeline in Disc properties – this makes the Main Timeline VTS 01.
    Otherwise, timeline creation order determines video title set order.
