Activity Forums Apple Final Cut Pro Legacy Setting Tiff/JPEG Still Images Duration to 1 Frame
  • Setting Tiff/JPEG Still Images Duration to 1 Frame
    Posted by Joe Taylor on January 7, 2010 at 2:57 am
    Hello All,
    I’m trying to import a sequence of still images that have been converted to TIFF frames (250 stills) and would like to import them in a batch setting were each image has the duration of one frame. I had no problem doing this when using FCP 5, but now that I am using FCP 6, all my images are 10 sec.
    IS there a way to automatically set FCP 6 so that when importing still images the set duration can be just 1 frame (or any length for that matter)?
    Joe Taylor replied 16 years, 8 months ago 3 Members · 3 Replies
  • Josh Olenslager
    January 7, 2010 at 3:05 am
    I believe it is the system settings where you can define this — might be user prefs though. Look for still frame duration and set to your duration. Generally when I’ve worked with image sequences, I open them in quicktime and then import that into final cut. I guess it depends on what you’re doing in edit though.
    Good times.
    Josh
  • Tom Wolsky
    January 7, 2010 at 3:28 am
    User Preferences>Editing. Set the Still Import/Freeze Frame preference at the top to one frame.
    If you really have an image sequence that you want to make into a movie you might try using the QT player File>Open Image Sequence, set the frame rate and then export to whatever video codec you need.
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP7,” “Basic Training for FCS” and “Final Cut Express Made Easy”
  • Joe Taylor
    January 7, 2010 at 5:46 am
    Hello Josh & Tom,
    That works! I appreciate your help!
    Joe Taylor
