Activity Forums Adobe Encore DVD setting poster frames in Premiere Pro
  • setting poster frames in Premiere Pro
    Posted by Bfavre4 on May 12, 2005 at 7:24 am
    I know that chapter points can be set by using unnumbered markers in Premiere Pro. After exporting as m2v from PPro, Encore will read the embedded chapter points. What about poster frames? Is there a different kind of marker in PPro that embeds and notifies Encore of poster frames?
    The whole point of setting chapter points in Premiere Pro is so that you don’t have to manually do ANY chapter work at all in Encore. But if you can’t set poster frames in PPro, then you still have to do a lot of tedious chapter work in Encore.
    Tim Kurkoski replied 21 years, 4 months ago 2 Members · 1 Reply
