Activity › Forums › Adobe After Effects Expressions › Setting position with a Dropdown Menu Controller
  • Setting position with a Dropdown Menu Controller
    Posted by Matthew Ingram on November 18, 2024 at 1:52 pm
    Hi there,
    I am trying to set a position on layers with a Dropdown menu controller on each layer. This code I have cobbled together is not working correctly. Option 3 puts the line where Option 1 should. And vice versa. And Option 2 is the same as Option 1. Very confused! Any help would be massively appreciated.
    Thank you!
    dropdown = effect(“Line”)(“Menu”).value;
    dropdown==1 ? value : [60,1018];
    dropdown==2 ? value : [60,947];
    dropdown==3 ? value : [60,876];
    Brie Clayton replied 1 year, 10 months ago 3 Members · 3 Replies
  • Dan Ebberts
    November 18, 2024 at 2:03 pm
    Try it this way:
    dropdown = effect("Line")("Menu").value;
    if (dropdown==1){
    val = [60,1018];
    }else if (dropdown==2){
    val = [60,947];
    }else{
    val = [60,876];
    val
  • Matthew Ingram
    November 18, 2024 at 2:05 pm
    That works like a dream. Thank you so much, Dan. I am so grateful.
  • Brie Clayton
    November 18, 2024 at 6:53 pm
    Thank you for solving this, Dan!
