Activity Forums Compression Techniques Setting max width and max height
  • Setting max width and max height
    Posted by Brandon Tate on February 16, 2011 at 4:08 pm
    Is there a way to set the maximum width and maximum height when converting a video? I’d like to maintain the aspect ratio. I’d like the video to not change size unless it is larger than the given max width/height. Is that possible via command line?
    Brandon
    Michael Rampe replied 15 years, 7 months ago 2 Members · 1 Reply
  • Michael Rampe
    February 16, 2011 at 10:23 pm
    [Brandon Tate] ” I’d like the video to not change size unless it is larger than the given max width/height. Is that possible via command line?”
    Yes but not in a single command. I have a script that does this by doing an input analysis to identify the size, running some very simple logic to determine if it is larger than what is required and setting/using variables to write the FFmpeg command size options based on the results of the logic.
    [Brandon Tate] ” I’d like to maintain the aspect ratio.”
    Display aspect ratio or pixel aspect ratio?
    Michael
