Activity Forums Adobe After Effects Expressions Setting Max and Min Values To Opacity
  • Setting Max and Min Values To Opacity
    Posted by Criis Daw on November 13, 2012 at 12:37 pm
    Can any on help me
    I am trying to set Setting Max and Min Values To Opacity where the opacity is linked to the layers scale
    so if a layer is scaled to 50% it is 50% transparent. Easy enough so far.
    but i want to set a min value of transpareny to 15% and a max to 85%
    so a scale above 85% will result in opacity of 85% no matter how much bigger it gets like wise smaller than 15% scale the opacity remains at 15%
    any help much appreciated
    Criis Daw replied 13 years, 9 months ago 2 Members · 2 Replies
  • Dan Ebberts
    November 13, 2012 at 2:07 pm
    Something like this should work:
    s = transform.scale[0];
    clamp(s,15,85)
    Dan
  • Criis Daw
    November 13, 2012 at 2:38 pm
    thanks dan..
    i knew it had to be simple.
