Activity Forums Adobe After Effects Expressions Setting Layer Postion
  • Setting Layer Postion
    Posted by Stephen Botting on September 21, 2010 at 10:42 pm
    I am working a project with nearly 400 layers, and have been using Expressions to place the layers in time(time remapping) and position.
    But have started playing in extendscript to write a script that can place the layers in time and position before rendering, to save evaluating the expressions every frame.
    I have successfully got my layers to start at the correct time, but when I try to set their position they don’t move and the script reports no errors, any ideas how this is done.
    Stephen
    var selectedLayers = app.project.activeItem.selectedLayers;
    for (i = 0; i < selectedLayers.count-1; i++) {
    selectedLayers[i].position = [100,100]; //just an example position
    //also tried
    selectedLayers[i]("position") = [100,100];
    selectedLayers[i].position.value = [100,100]; //returns value is readonly
    selectedLayers[i].postion.setValue = [100,100];
    Stephen Botting replied 15 years, 11 months ago 2 Members · 2 Replies
  • Chris Wright
    September 21, 2010 at 10:53 pm
    this
    myLayer.property(“Position”).setValue(theVal1);
    or this
    theLayer.position.setValue([1632,1224,0]);
    not this.
    https://technicolorsoftware.hostzi.com/
  • Stephen Botting
    September 21, 2010 at 11:34 pm
    Thanks for the reply, I’m assuming from this that I need to include the Z position even when the layer is 2D.
    Worked great once I looked at your code properly.
    Cheers,
    Stephen
    https://www.43south.co.nz
