Activity › Forums › Apple OS X › Setting hard disk spin-down time on Tiger
  • Setting hard disk spin-down time on Tiger
    Posted by Iamfoxman on October 8, 2005 at 10:31 pm
    I’m having issues w/ my G5 dual 2.7ghz machine running fcp 5 and getting dropped frames error on edit-to-tape function when media is spread over multiple drives…
    I think that it is due to the hard drive spinning down that is not in use- then fcp calls for media from that drive & it isn’t spinning at speed when it’s needed- thus the dropped frames…
    HELP!!!
    How do I set the hard disks to not spin down or to a longer delay???
    Don Greening replied 20 years, 11 months ago 2 Members · 1 Reply
  • Don Greening
    October 9, 2005 at 10:08 pm
    Can you not just go to the energy saver preferences and un-check the box at the bottom of the window that says: “put the hard disk(s) to sleep when possible.” ? Or have you done that already? Other than that I used to use a shareware program called “spindown fix” that wouldn’t allow any internal or external hard drives to go to sleep. I used it in Panther but I don’t know if it’s okay to use in Tiger. Google “Spindown Fix” and it should come up.
    – Don
