Activity Forums Web Design (WordPress, Joomla, etc.) Setting form values without a drop down
  • Setting form values without a drop down
    Posted by Tumblemonster on September 7, 2005 at 4:54 pm
    I am building a web site that allows a user to click on a button to change the fabrics shown in an image of a clothing item. This allows the user to see what their custom designed clothing looks like before they purchase it. I am show/hiding floating layers containing various fabrics to create the effect. What I need to do is set the values that would normally be in a popup menu. I want them set on the buttons click, so when the submit button is pressed it reads these values.
    Anyone have an idea?
    -tm
    Curtis Thompson replied 21 years ago 2 Members · 3 Replies
  • Curtis Thompson
    September 7, 2005 at 5:05 pm
    hello…
    not really following you perfectly – do you want to set the values of a popup dynamically? so like clear the current values and create new options in it? or did you just want to provide values for form elements?
    sitruc
  • Tumblemonster
    September 7, 2005 at 6:39 pm
    I just want to provide values for form elements.
    -Jason
  • Curtis Thompson
    September 7, 2005 at 6:46 pm
    hello…
    then something like this should work (a very simple example):
    <SCRIPT LANGUAGE=”JavaScript”>
    function setValues (formEl, val) {
        formEl.value = val;
    </SCRIPT>
    with formEl being the form object (so like document.myForm.myValue). then trigger that somehow – with an onClick on a button or something like that – then you can also customize it to set select values or other text field values as needed.
    still not sure what type of field you want to set a value for, so for now i’ll assume hiddens…but if this is too general an example, then you might find more what you’re looking for here:
    https://irt.org/script/form.htm
    or feel free to ask me to clarify!
    sitruc
