Activity Forums Blackmagic Design Setting for HVX200
  • Setting for HVX200
    Posted by Mike Savino on February 19, 2007 at 2:36 am
    I have a multibridge pro and I’m trying to get a listing of the correct settings to use with DVCProHD footage shot from the HVX200.
    Every setting I choose I have to render once put into the canvas in FCP. There are so many choices are there a couple that should be use?. The DVCProHD choices don’t sync out of the MBP box on the monitor. Is this the way the workflow is with the MBP or am I missing something?
    I shoot in both 1080i and p and 720p.
    Thanks for any help.
    Mike Savino replied 19 years, 7 months ago 2 Members · 2 Replies
  • Kristian Lam
    February 20, 2007 at 9:14 am
    Hi Mike,
    You have to be more specific about how you’ve ingested you clips (whether pulldown was applied) and what frame rate they were shot in. Remember to create a new sequence after selecting the easy setups. The setups do not affect exisiting sequences.
  • Mike Savino
    February 20, 2007 at 12:25 pm
    In 1080, I shoot 60i, and 30p
    In 720, I shoot 30p with variable frame rates ranging from 12 to 60 fps.
    I bring the files in via the P2 import in FCP.
    I’m not sure if pull down is applied.
