Activity Forums Adobe After Effects Expressions Setting Font and Font Size (style.setFont & style.setFontSize) AE 2020 issue
  • Setting Font and Font Size (style.setFont & style.setFontSize) AE 2020 issue
    Posted by Ronan De lacy on November 21, 2019 at 2:47 pm
    Hello expressionists,
    I’m having an issue setting the font and font size with the new expression features in AE 2020.
    I have a text layer, with 2 drop down menus applied. One for the typeface, the other for font size. Both menus have a parseFloat expression applied to get there value form 2 dynamic text layers connected to a JSON file. Everything is working as it should with the parsed values.
    The issue I’m facing is that I can only set either the font-size or the type-face, but not both. Below is the expression that I’ve applied to my Source Text. Both x and y work independently, but not together.
    I think the problem is down to how I’ve structured the expression. I’ve tried to solve, but I’m lost. Any advice/help greatly appreciated.
    Thanks in advance,
    Ronan
    var x = effect("type-face")("Menu").value;
    var y = effect("font-size")("Menu").value;
    if ( x === 1 ) {
    style.setFont("Helvetica-Light");
    } else if ( x === 2 ) {
    style.setFont("Helvetica");
    } else if ( x === 3 ) {
    style.setFont("Helvetica-Bold");
    } else if ( x === 4 ) {
    style.setFont("HelveticaNeue-Thin");
    if ( y === 1 ) {
    style.setFontSize(240);
    } else if (y === 2) {
    style.setFontSize(200);
    Ronan De lacy replied 6 years, 10 months ago 2 Members · 2 Replies
  • Dan Ebberts
    November 22, 2019 at 12:36 am
    I haven’t tested this, but try it this way:
    if ( x === 1 ) {
    style = style.setFont("Helvetica-Light");
    style = style.setFont("Helvetica");
    style = style.setFont("Helvetica-Bold");
    } else {
    style = style.setFont("HelveticaNeue-Thin");
    if ( y === 1 ) {
    style = style.setFontSize(240);
    } else {
    style = style.setFontSize(200);
    Dan
  • Ronan De lacy
    November 22, 2019 at 8:48 am
    Dan, thanks so much. That did the trick!!
    Cheers,
    Ronan
