Activity › Forums › VEGAS Pro › Setting event opacity with envelope SOLVED but weird
  • Setting event opacity with envelope SOLVED but weird
    Posted by Nick White on July 23, 2019 at 5:53 am
    OK. I then found that envelopes can be hidden. The help is vague….select the envelope you want to hide….
    When I asked to View Video Envelopes, all were ticked. I unticked the Composite choice and then re-ticked it _then_ it appeared.
    I can see how to adjust the entire event’s opacity, but I need to adjust it over time, as it plays through.
    I have watched a couple of videos and they say that you right click the track header and ask to insert an envelope, then choose Composite. This apparently should cause a purple line to appear at the top of the track’s events, and that this can have points added to it, so that you can then do enveloping.
    However when I tried it, even though I was able to locate and set the Composite Envelope switch, although the existing opacity line showed still, there is no purple line, and I cannot add locations along a line to alter opacity over the play time of the clip.
    I have tried double-clicking and right-clicking the default opacity line.
    If I read Vegas MS 16 help, it does not mention the ability to create opacity envelopes, that I can find.
    Is there a way to do this in 16 MS?
    Any help appreciated.
    Nick
    Head: Hertz Music
    Movie Studio…version 12, 15, 16 Suite. Win 7 64 bit.
    Nick White replied 7 years, 2 months ago 2 Members · 2 Replies
  • Dimitrios Papadimitriou
    July 23, 2019 at 10:17 am
    Hey there. The last version of MS I used was 10 had composite envelopes so I’m sure 16 does as well. To insert a composite envelope right click on the track you want it on, I disable headers but it should work on the track on the main body of the media. From here you will have a line going down the center of the track, you can create points and adjust them up or down, with 2 points you can create a gradual opacity reduction.
  • Nick White
    July 23, 2019 at 10:40 am
    Yeah, but the weird thing is that although the View/Video Envelopes were all ticked, the envelope did not show until I un-ticked and re-ticked it. Shrug….
    Anyway, thanks.
    Nick
    Head: Hertz Music
