Activity Forums Adobe After Effects setting duration for tiffs in sequence
  • setting duration for tiffs in sequence
    Posted by Lisa Simonson on May 26, 2009 at 7:00 pm
    Hi:
    I’ve imported a tiff sequence to AE, 320 pics to be rendered out as a q-time movie. First time I rendered the movie ( imported as comp ) it came out jumpy. Now I’m trying to import files as individual pics and set each frame w cross dissolve, each tiff 2f. My problem: tiffs come in as 20 sec each. All tiffs are selected in timeline. I go to Animation, keyframe assistant, sequence layers. set to 2F but they still remain @ 20 sec.
    My comp is set to 20 sec.
    Is there a way to set duration to 2 frames for all tiffs at once in the 20 sec comp?
    Or : What would be the best compression to render out a less jumpy q-time?
    ( First time I used no compression )
    Tiffs are exported from C4D.
    Thanks anyone!
    Lisa Simonson replied 17 years, 4 months ago 2 Members · 2 Replies
  • Steve Roberts
    May 26, 2009 at 7:14 pm
    Select all the tiffs in the timeline, move the current-time indicator (playhead) to frame 1 (not 0) and hit ]. Then sequence the tiffs.
    BTW, “none” compression would make a jumpy quicktime because it’s too big for your drive to play back smoothly. Use Animation for sending the movie to another program (lossless quality) or maybe Photo-JPEG to play it back on the hard drive. regarding the ideal codec, it depends on what you want to do with the file after you render it.
  • Lisa Simonson
    May 26, 2009 at 8:25 pm
    Thanks for the tips!
