Setting Disc Volume Name / PS3 Disc Art
Hello All,
I have DVDA 6 Pro. I am burning to BD-RE (re-writable) which might be the issue. When I burn my project, the change volume name setting in the make disc dialog is grayed out and defaults to VOLUME_01. I can change this via File, Properties, Disc Properties, Volume name, but it does not reflect the volume name when I burn it. My thoughts are:
1) The BD-RE disc does not allow this
2) Is it possible I need to re-render the disc image file after changing the volume name in the properties? I have been using the previously prepared project when I burn and it seems to me like it is the burn process and not the previously prepared .iso file that determines the volume name.Now for the PS3 issue. How do I get the name (volume name I assume) to show up on the PS3 before I select it. Most Blu-Rays have the name of the disc with a small picture next to it when displayed on the PS3 menu. Is this something the PS3 pulls from the web or is it on the disc? I have an old Blu-Ray I burned and when I put it in my PC, the volume name, I somehow once set, shows up under the drive icon. When I put it in the PS3 it reads “BDMV BR-E”. My new project simply says “VOLUME_01” on the PC and “BDMV-RE” on the PS3. Any thoughts? Thanks!
