Activity › Forums › VEGAS Pro › Setting Default Import Properties
  • Setting Default Import Properties
    Posted by Frankie Jones on August 24, 2013 at 9:38 pm
    Hey,
    Does anybody know how to set default clip import properties. I import a lot of clips with unmatted alpha channels and want to save some time having to go to properties on each clip changing it from none to unmatted. Can do this with excalibur ofc for multiple clips but was hoping a default setting could be set up for this purpose.
    Mike Kujbida replied 13 years, 1 month ago 2 Members · 1 Reply
  • Mike Kujbida
    August 25, 2013 at 1:52 am
    Add an event (what Vegas calls a clip) to your timeline.
    Right click it, select Properties, switch to the Media tab, change the Alpha channel to the desired setting and then click the floppy disc icon next to the Stream line as shown below to save the selection.
    All events like this will automatically come in the same way.
    Be advised that if you bring in something different (for example, a PNG file instead of a TGA file), you’ll have to repeat this process.
