Activity › Forums › VEGAS Pro › setting default audio fade type in Sony Vegas Pro 12
  • setting default audio fade type in Sony Vegas Pro 12
    Posted by James Redmond on April 7, 2013 at 8:06 pm
    Hi!
    I’ve been searching for a solution to change the default audio type to the one I use most of the time. I found how to get to the internal preference (ctrl, shift, plus preferences), but have not found the correct field and value to change.
    anyone have any idea?
    thanks for your assistance. James
    James Redmond
    Dynamic Videos, Inc.
    Rogers, AR USA
    Gilles Gagnon replied 12 years, 9 months ago 4 Members · 8 Replies
  • 8 Replies
  • Graham Bernard
    April 7, 2013 at 8:44 pm
    Are you speaking of the Audio fade that results from makkng a Split?
    G
  • James Redmond
    April 7, 2013 at 8:59 pm
    Graham,
    No.
    I am talking about any audio clip, that when you take the end of the clip and do a audio fade (lets say a fade in), it uses a fade type that I do not use and I have to manually change the fade type each time.
    It seems that there has to be a way to set those default fade type in preferences.
    Thanks, James
    James Redmond
    Rogers, AR USA
  • Graham Bernard
    April 7, 2013 at 10:47 pm
    [James Redmond] “It seems that there has to be a way to set those default fade type in preferences.”
    OK, Gary James has an Extension Script that will allow you to apply different Offset Fade “types”. I’ve been wanting a reason to trial it for this, and yes it does work.
    So, I can’t see a default option but at least your can apply a Script that will alter the Offset Fade Type.
    G
  • Aleksey Tarasov
    April 8, 2013 at 6:08 am
  • James Redmond
    April 8, 2013 at 3:41 pm
    Aleksey, That does not change the default audio fade type for me.
    Graham, I do have add-on programs that will change it after the fact. It just seems like we should be able to set up what the default fade type would be.
    thanks for both of you looking into it. Still don’t have a satisfactory solution.
    All the best, James
    James Redmond
    Rogers, AR USA
  • Graham Bernard
    April 8, 2013 at 4:21 pm
    Yup. After the fact.
    Perhaps Aleksey has a way to effect the Default from what he was offering.
    Hmmm…
    G
  • Aleksey Tarasov
    April 8, 2013 at 5:38 pm
    From Help: “This setting is used only for events that you place on the timeline after changing the setting. Existing events will use the default fade type that was active when they were added to the timeline.“
  • Gilles Gagnon
    December 12, 2013 at 5:11 pm
    Thanks for this fellows!
    I had the exact dilemma today. Great solution.
    Cheers,
    G
    Gilles
