Activity Forums Apple OS X setting default applications
  • setting default applications
    Posted by Paul Nevison on October 18, 2006 at 8:42 pm
    hey there
    where can I set up which are the default applications to open certain file types. Since installing After Effects 7, every file is now trying to be opened by after effects.
    thanks for any help
    G5 DP 2.0 (Power PC)
    4.0G RAM
    OS 10.4.8
    QT 7.1.3
    FCP 5.1.2
    BMD Decklink Extreme 5.7.1
    PAL Land
    Paul Nevison replied 19 years, 11 months ago 4 Members · 10 Replies
  • 10 Replies
  • Curtis Thompson
    October 18, 2006 at 9:06 pm
    hello…
    [right click or file menu] -> get info
    sitruc
  • Paul Nevison
    October 18, 2006 at 9:17 pm
    hey Curtis
    I’ve tried right clicking on the app icon in the applications folder and there isn’t an option to set as default…can you be a little more specific as to where i need to look
    thanks
    4.0G RAM
    OS 10.4.8
    QT 7.1.3
    FCP 5.1.2
    PAL Land
  • Curtis Thompson
    October 18, 2006 at 9:33 pm
    hello…
    ya…sorry – i guess my steps were cryptic…
    1. either right-click or go to the file menu
    2. choose “get info”
    (then go from there)
    sitruc
  • Paul Nevison
    October 18, 2006 at 9:43 pm
    Hey Curtis
    yes I am familiar with the get info window…it’s just that I cant find a drop down menu or check box that has anything to do with setting up a default option
    4.0G RAM
    OS 10.4.8
    QT 7.1.3
    FCP 5.1.2
    PAL Land
  • Paul Nevison
    October 18, 2006 at 9:50 pm
    hey curtis
    here is what I’ve found so far….when i bring up the get info window for individual QT files there is an “open with” drop down…this is currently set to AE 7
    i can select another app such as FCP or QT and then click the change all button to i assume make a global change to all similar files. the problem is that when i select a new app as the default and then click the change all button – nothing happens…if i close the window and then reopen it AE 7 is back as the default option….any ideas??
    4.0G RAM
    OS 10.4.8
    QT 7.1.3
    FCP 5.1.2
    PAL Land
  • Curtis Thompson
    October 18, 2006 at 10:09 pm
    hello…
    sorry – hard to troubleshoot your specific issue from here wih that description… :-/
    (with hope this is a known issue to somebody else)
    sitruc
  • Chuck Reti
    October 19, 2006 at 4:41 am
    Have you done a Permissions Repair recently or ever? (Disk Utility>select volume, Repair Disk Permissions).
    In the Get Info window, after selecting a new Default app using the pulldown and clicking the Change All button, have you tried either logging out and back in, or restarting?
  • Michael Trauffer
    October 23, 2006 at 2:16 pm
    paulos,
    The “change all” button in the “Get Info” window is exactly what you use to change the default application.
    Michael R. Trauffer
    Apple Pro Certified, Final Cut Pro 5-Level 1
  • Paul Nevison
    October 24, 2006 at 11:36 am
    hey there guys
    I’ve been away for a few days and have only just got back. the problem I am having is that the “change all” ie default button – is having no effect. it seems that AE 7 has taken over my machine!!
    i routinely repair permissions and have restarted several times to no avail. I have unistalled and reinstalled AE7 and am having the same issues.
    This is really puzzling
    4.0G RAM
    OS 10.4.8
    QT 7.1.3
    FCP 5.1.2
    PAL Land
  • Paul Nevison
    October 24, 2006 at 11:49 am
    now something strange. AE7 is now no longer the default to open movies…that has now become quicktime, this after changing default in the get info window (for some reason this time it worked)
    but now other files such as installers and word documents will not launch as no application has been set as the default. this is easy enough to rectify with word docs etc… but what app do i need to select in order for installers to launch?
    thanks
    4.0G RAM
    OS 10.4.8
    QT 7.1.3
    FCP 5.1.2
    PAL Land
