Activity Forums Adobe After Effects Setting Antelop text effect duration
  • Setting Antelop text effect duration
    Posted by Wey Loh on April 5, 2008 at 10:11 pm
    Is there a way of setting duration of the Antelop text effect in After effeccts cs3? it currently only lasts 3 secs. i need it to be atleast 5 secs
    Mike Clasby replied 18 years, 5 months ago 2 Members · 2 Replies
  • Mike Clasby
    April 6, 2008 at 6:26 am
    Select the text layer that has the preset applied to it, then hit “UU”” and anything done to the layer will be revealed.
    Now you can slide the ending keyframes to the right. And for Tracking in this case you need to select the middle keyframes and change them to Roving keyframes to keep the timing proportional (see HELP file).
    OR
    Just Time stretch the layer with Layer>Time Stretch.
  • Mike Clasby
    April 6, 2008 at 10:42 pm
    On that Tracking Amount, to slide the keyframes proportionately, just select all the keyframes and Alt-Drag the end one to lengthen all (proportionally).
    I just got that from Antony Buonomo above. Can’t believe I didn’t know that, thanks Antony.
