Activity Forums Adobe After Effects Setting and Animating Gradient Fill
  • Setting and Animating Gradient Fill
    Posted by Andreas Sizynski on December 2, 2012 at 7:05 pm
    Just for clarity, I am trying to reproduce a similar effect as seen in the motion gaphics intro for this clip, from 00:00 to 00:002
    https://www.youtube.com/watch?v=WVAJBR07ryQ
    Notice how the NODE text fill proceeds downwards, filling in the alpha. Ultimately, I am trying to get my own Text Layer’s opacity fill to not only increase in value, but the actual change in opacity to start at a certain point, and “spread”
    In another thread, I specified my goal, and it was suggested to “Convert the text to a shape layer and animate the gradient fill, which has opacity stops as well as color stops.”
    I have converted the text layer into a shape layer, but I am still stuck:
    I found the “gradient” button, but I have not found an “animate gradient” option.
    Also, how can you adjust the status of the gradient?
    Is there a way to make a gradient act as an alpha mask?
    right now, all that I see is a solid black and white linear gradient with no option to set a “fade to alpha” gradient in the Fill settings.
    And I have no idea where the menu to actually animate the gradient actually is.
    Vishesh Arora replied 13 years, 9 months ago 2 Members · 3 Replies
