Activity › Forums › Avid Media Composer › Setting a “poster frame” in frame view.
  • Michael Phillips
    November 26, 2011 at 2:46 pm
    Select one or the clips:
    1. Single frame advance key moves all frames + 1 frame
    2. 8/10 frame advance key moves all frames + 8/10 frames
    (reverse is true in both cases)
    On a single clip:
    1. Load and play in source monitor to desired frame and Mark IN
    2. Play directly from bin to desired frame and Mark IN
    Then use the “got to mark in” (Q key) and all clips will go to that mark.
    Michael
    Michael Phillips
